Studio 5000 help
DoubleJ
Oct 2017
midwest
I recently got a new laptop and installed all my Rockwell software to it. I transfered my activations which went well. I went to open a previous program I had created in the past and it will not let me open it. States it has been generated with a previous version. I installed ver 31 this time and have not been able to either remove it to the point I can install a previous version. It keeps telling me I have a newer version installed and stops. I've followed Rockwells support page to even manually remove it in the registers. When I open the software and start a new program it only provides me with version 31 when in the past I had the option all the way down to 24 I believe. Any ideas what i can do. I don't want to have to change the version in all my programs to accomodate this issue. I did not have to in the past.
Is you new PC running Windows 10
all versions of RSLogix 5000 are not supported in windows 10
you may have to use a VM machine
I hade the same problem when I upgraded my PC early versions of Windows 10 ran fine but after updates things didn't work that well
Tech Connected can give you a list of versions but they recommender to me that I use a VM running Windows 7 but check with them.
unless you want to upgrade the program you must open it in the original version You should get a popup message asking if you want to do a one way version upgrade.
if the original program was 24 then you will need 24
I think 10 - 30 are software upgrades but 31 and up are completely separate programs.
If you have tech connect contract you can download any or all versions you want
I hope that helps
Please see attached file. I need this program in Function Block form but I am totally lost on this. Any help would be appreciated. Thanks!
303
does anyone know how to fix the icons on the tool bar they disappeared about a week ago this is on studio 5000 any help would be grate?
1,914
Hello, We are beginning to use the View Designer software for the newer Panelview 5500 and 5300 HMIs. I one we are starting with is the 5300 10"...
1,207
Hi guys, New guy here. I was wondering if anyone could please show me how to write these out in ladder logic. I am struggling with them. Thanks!
51
9,633
Hey everyone. I'm new to programming and am currently the only one who does any in my workplace. I have access to rs logix 500 pro, and ccw, but...
2,031
