Studio 5000 v31 Fatal Errors
hecti.brown
Jun 2017
Montreal
Started my first program in v31 for work at the end of last week, our templates are all v30 and I am the first to start using v31. Everything was great until i had to start modifying our UDTs and Aliases. I have been getting lots of fatal errors whenever I need to modify any of the above. I was just wondering if anybody else is having the same issues.
Supposed to be releasing soon another point update to version 31, along with an emulator for it.
TIP: It's usually best to provide us the specific Fatal Error message details so we can zone in on specific help (if it exists, I'll find it!) without guessing what it is from a more vague description.
However, while we wait for those details (if you do want to provide them), here is one example of a possible cause/solution from the Rockwell Automation Knowledgebase...
61277 - Studio 5000: Fatal Error 0x80042001
Access Level: TechConnect
In case you cannot access that?...
Cause:
When editing a UDT in v30 of Studio 5000
Error 0x80042001 (-2147213311)
RxE_NOT_FOUND - Requested item could not be found.
Solution:
Do the following:
Restart RSLogix 5000
Save the project as an .L5K file
Reopen the .L5K copy with RSLogix 5000
Note: The "Cause" there may be similar to your situation, but the "Solution" may not be the fix for you, depending on whether or not that specific Error message is the same as yours.
But trying that solution certainly cannot hurt.
Regards,
George
Hi everyone: I need to upgrade my Studio 5000 to from V31 to V33, but when I try to download from Rockwell PCDC, I only have the option up to 31...
1,412
Guys, beating my head on a wall here. I have two simple date-times and I want to find the oldest. Are there any better ways to do this beside a...
3,523
  • Poll
Hello Everyone, Is it a good idea to make the switch from 31.011 to 32 or 33? I am currently using 31.011 on all of our 5370 L33 or L36...
7,811
When starting installation of Studio 5000 I get option to install it on C: disk as default. When I change it to disk D: I see that it still wants...
2,969
