Studio View Designer
d21x
Jul 2008
Illinois
30
Hey guys anyone have an example program in Studio View Designer. I am used to FT View. I don't have Tech Connect so I can't download their example. Any help would be appreciated. Thanks.
I did a project in View Designer using only the PLC tags and some PanelView internal predefined tags. At this time I can't recall if you can create local tags in the PanelView.
View Designer is quite different from FT
There are plenty of free official stuff you can download from Rockwell and YouTube as well as some stuff from forums in the Internet
Rockwell Automation Knowledgebase
725030
725031
725032
725033
821660
929778
1071447
1071822
1073795
1073798
1074050
(.mp4 files)
PanelView 5000 Family Introduction
Studio 5000 View Designer - Security
Studio 5000 View Designer and PanelView 5000- Getting Started
Studio 5000 View Designer and PanelView 5000- Introduction to Add-on Graphics
Studio 5000 View Designer and PanelView 5000- Introduction to Alarming
Studio 5000 View Designer and PanelView 5000- Introduction to Language Switching
Studio 5000 View Designer and PanelView 5000- Introduction to Navigation
Studio 5000 View Designer and PanelView 5000- Introduction to Property Binding
Studio 5000 View Designer and PanelView 5000- Introduction to Data Logging and Historical Trending
Studio 5000 View Designer and PanelView 5000- Introduction to Loading from Removable Media
Studio 5000 View Designer and PanelView 5000- Introduction to PDF Viewer
Studio 5000 View Designer and PanelView 5000- Introduction to VNC Viewer
Forums:
http://www.plctalk.net/qanda/showthread.php?t=113900
Hope this helps
Bye
d21x said:
Thanks for the example.
Question, sorry if this is silly, but where are the tags? That's the most confusing thing for me right now is where do I put tags. Thanks!
You are most welcome.
The tags are in the controller. Only direct reference tags are currently supported.
The following technote briefly outlines some of these features/limitations, however you want to look at it...
725032 - PanelView 5000 Communications FAQ
Access Level: Everyone
725032 said:
How are tags created in a PanelView 5000 application?
All PanelView 5000 application tags will be direct reference, meaning that the application configuration will select existing tags from a Studio 5000 Logix Designer application rather than creating any “HMI tags” within the Studio 5000 View Designer application.
How many tag references can be configured in a PanelView 5000 application?
A recommended maximum of 5,000 tags can be configured per PanelView 5000 application. Of these 5000 tags, 256 can be designated as Class 1 communications.
Regards,
George
Regards,
George
George,
Your example didn't have any references to tags and didn't have any buttons with tags. So it didn't help much. Thanks anyways.
I probably didn't explain what I was having problems with, but after messing around for a while I did find what I was looking for. If I make a button and want to assign a tag to that button, I go to the property manager, events tab, make a touch press, pick toggle, and then assign a tag to it. I'm used to FT View where assigning the tag was simply in the connections tab. Thanks everyone.
Question for those who are in the know how Studio 5000 works/compiles under the hood. The laptop that was supplied to me is now full with no...
583
Hello, We are beginning to use the View Designer software for the newer Panelview 5500 and 5300 HMIs. I one we are starting with is the 5300 10"...
1,227
Hi, sorry for the newb question here, can you dereference an array in a numeric display? When I go to the expression editor, it doesn't seem to...
1,113
Hi all, I'm new to using the View Designer for HMI development. We have at least one Panelview 5000 series using this software and would like to...
2,466
Hi all - (Using Logix Designer 33.01, View Designer 8.01 on PV5310) I'm having trouble with pushbuttons either not appearing (in emulator or on...
1,470
