Studio5000 Exporting Data to a Spread Sheet
RedwingRazor
Oct 2018
Detroit
35
I have been tasked with something I have never done before and not having much luck searching for a solution.
I have a cell that requires a badge scan to accept a particular inspection. I record the badge number with the year, month, day, hour and minute. The logic is written and works.
I created a UDT of 6 DINTs called Badge_Log. I then created an array of 200, data type Badge_Log.
I need to extract the data from that array to some sort of spreadsheet. That is where I am stuck.
Any ideas?
o_O
Have a look at AdvancedHMI. You can rip all that data out of the PLC and stick it in a DB or write it as a spreadsheet using your own program made is MS Visual Studio and Archie's magical comms drivers.
Otherwise you can do some freaky stuff with rslinx professional and DDE Topics, and VBA. Not recommended as its pretty fragile.
Well just in case you want to try the python route...
I assumed that you had a tag named Badges. it's members are BadgeNumber, Year, Month, Day, Hour, Minute. It's a length of 200, so something like Badges[0].BadgeNumber, Badges[0].Year and so on...
Install Python (2.7 or 3.5)
Download pylogix: https://github.com/dmroeder/pylogix
Create a new file in the pylogix directory, say csv_file.py
Paste the code from below into csv_file.py (you will have to edit the tag names and IP accordingly)
Run it, you should get a CSV file named data.csv with your data
Code:
import csv
from eip import PLC
Variables you may have to change
Tag names will be generated based off of these parameters
so in this case you would end up with tag names like:
Badges[n].BadgeNumber, Badges[n].Year, etc...
plc_address = '192.168.1.20'
base_tag_name = 'Badges'
udt_members = ['BadgeNumber', 'Year', 'Month', 'Day', 'Hour', 'Minute']
array_len = 200
Build a list of tag names based off of the base tag name, size of the
array and the members of the UDT
tag_list = []
for i in range(array_len):
    tag_list.append(['%s[%d].%s'%(base_tag_name,i,m) for m in udt_members])
Read the values of all of our tags in the list we built
values = []
with PLC() as comm:
    comm.IPAddress = plc_address
    for t in tag_list:
        values.append(comm.Read(t))
Write the values into a new CSV file
with open('data.csv', mode='w') as csv_file:
    writer = csv.writer(csv_file, delimiter=',', quotechar='"', quoting=csv.QUOTE_MINIMAL)
    writer.writerow(udt_members)
    for v in values:
        writer.writerow(v)
I noticed that in Windows, my above code will skip lines when writing to CSV.
Adding lineterminator='\n' as shown below will fix that:
Code:
writer = csv.writer(csv_file, delimiter=',', quotechar='"', lineterminator='\n', quoting=csv.QUOTE_MINIMAL)
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
154
Hi Hope you all are doing well. Iam working on a project with some AOI. I also hate no online edits... lol. My problem occurs when I use a UDT...
161
I am not sure if this is possible but if there is a way, you guys would be the ones to know. I am currently working on a project where we are...
222
Hi all. I'm having issues adding an ethernet module to my project in Studio500 v34. The device is a Fredericks Televac EthernetIP MX gateway which...
367
The day of week program started changing day of week 2 hours early. It changes at 10 P.M. instead of 12A.M. Just started this year.
22
2,676
