Studio5000 RAPID Equipment Interface - PACKML
italo2008
Feb 2009
Padova
95
Good morning all
Someone of you have experience with this toolkit and PackML? Mine is close to 0.
Customer ask us for PackML, and I found (or it seems to me) that this toolkit can help me to implement PackML without write too much code.
I downloaded the toolkit and import into the PLC project, It compiles without errors but I have some questions:
1. the "toolkit" consists of 1 AddON and all the required data types: does it need any license? It seems that I cannot read or modify internal code of AOI, is this only a read and write source protection or do I need a license?
2. Reading the quick start guide, it tells me that I can use this AOI for PackML , simply mapping PackTags to the structures that I found inside the toolkit, OR mapping directly packTags to the AOI interface. In the PackML example on the quickStart (at the end of chapter 2), it refers to PAckML_Data variable (wich contains all the packtags, I suppose), and the interface of the AOI is slightly different. I don't understand if somewhere I can find the dataType of the PackML_Data variable, or if I have to write it
Any ideas or suggestions?
thank you
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
154
Hi Hope you all are doing well. Iam working on a project with some AOI. I also hate no online edits... lol. My problem occurs when I use a UDT...
162
I am not sure if this is possible but if there is a way, you guys would be the ones to know. I am currently working on a project where we are...
226
Hi all. I'm having issues adding an ethernet module to my project in Studio500 v34. The device is a Fredericks Televac EthernetIP MX gateway which...
368
The day of week program started changing day of week 2 hours early. It changes at 10 P.M. instead of 12A.M. Just started this year.
22
2,680
