Studio5000 UDTs, aliases, and descriptions
Bbarnett
Jul 2013
United States
77
Is there a typical/standard way of when to use UDTs, aliases, and descriptions? When do you use one over the other? What are some pet peeves of yours that others do?
I rely heavily on UDTs but I'm not sure it's the best way to go for everything. For some reason I have Local IO aliased.. I guess I've always just done it that way. I don't use descriptions.
All three serve different purposes.
UDTs - Just good practice to ensure your code maintains structure and you don't end up with tags like this because someone was lazy:
Code:
HeatingZone1
HeatZone2
Heating_Zone3
Heating_Zone_4
Descriptions, yes they should be used.
Alias, I don't use them for IO addresses, but I do use them for array references and other program scoped tags which are aliased to controller scoped tags (InletValve := V101)
My biggest pet peeves
1. programming a ControlLogix like it's a PLC5/SLC (B[4].6, I[9]...)
2. Long_tag_names_that_try_to_replace_a_description
3. Not using features like AOIs and UDTs (gripe all you want about online changes)
4. Lack of a clear structure. Code that has structure is much easier to read and understand than code that just has long rung descriptions everywhere. A program with structure guides the eyes, making it much easier to follow and replicate without having to read questionable rung descriptions and the manic thoughts of the original programmer.
I agree 95% with what Paully said, but have a different take on #2.
Generally speaking, tag name's should be descriptive enough to not need a description. And it is ok if they are bit longer, within reason. Consider that most computer programming languages don't have both descriptions and names for their variables, just names. They are one and the same and for good reason. Having a descriptive name and a description is redundant. The situation where descriptions are required are for things like physical IO, where the tag name represents the slot and point but doesn't tell you what it actually is.
One of the beautiful things about UDTs is that once you have added documentation to the elements of the UDT declaration, the ladder display will use those descriptions in a "Pass-Thru" fashion, so you don't need to spend hours documenting your tag data. It also means you can't get a description wrong, or even slightly different !
.....Code that has structure is much easier to read and understand than code that just has long rung descriptions everywhere......
I've always said that if you can't describe what a rung is doing in the 5 or so lines that are visible by default, then the rung is too complex and should be broken up.
I once worked on code that was driving HMI animation values, and there were about 14 different states. Every rung had the same comment on, describing what the state values were, so you couldn't see them all.
I changed it to use a UDT for the state values, and initialised the named members to the correct values on S:FS.
The UDT members had descriptive enough names, so instead of MOV 5 Pump1_Status, I could use MOV Status.Overheating Pump1_Status, so much easier to read, and did not need rung comments at all.
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
167
Hi Hope you all are doing well. Iam working on a project with some AOI. I also hate no online edits... lol. My problem occurs when I use a UDT...
172
I am not sure if this is possible but if there is a way, you guys would be the ones to know. I am currently working on a project where we are...
230
Hi all. I'm having issues adding an ethernet module to my project in Studio500 v34. The device is a Fredericks Televac EthernetIP MX gateway which...
387
The day of week program started changing day of week 2 hours early. It changes at 10 P.M. instead of 12A.M. Just started this year.
22
2,705
