Suggestions on a 4-20ma Temp Probe
Minco, Omega Engineering
You will probably end up with an RTD and transmitter, not a direct 4-20 device. For high temp maybe T/C instead of RTD.
http://www.workaci.com/content/att100-r
I currently use this in my house. Its a simple RTD with a 4-20ma output. They come pre-programmed for a range plus they have old school zero and span pots for calibration. nice for only $110 dollars. They have all types of ranges and indoor/outdoor, RTD or Thermistor.
For process industry we use SICK or IFM transmitters which have a direct 4-20mA output.
Otherwise if it's just a regular old temperature probe stuck to a wall or something then it will most likely be an RTD connected to a 4-20mA 'hockey puck' style transmitter which you can get from most industrial thermocouple or temperature suppliers.
I have used Foxboro Temp transmitters in the past if you have to have a 4-20mA signal (no shutdown time, no more spaces for cards, etc. reason to need it). It comes in a range 0-300F is what i typically bought, but you lose a certain amount of accuracy vs RTD. If you need more info i can look up the model #.
I know this topic has been brought up a few times, but i had some specific questions. I have installed several 1783-NATR devices and they have...
315
I'd like people's opinions on which manufacturer of hardware they prefer. We are an aerospace manufacturing facility that does little to no SCADA...
535
I am setting up control for Hypochlorite dosing. The easy part is the dosing calculation for flow pacing but I would also like to setup trimming...
952
I'm working on an application and have hit a bit of a snag. I need to find an industrial touchscreen display that can: - Tolerate down to -40C...
760
Hello Everyone, I am reaching out to this knowledgeable community with a peculiar problem I've been experiencing with a PLC 5/40E. This issue has...
2,283
