Surface Mount Temperature Transmitters
Greg Dake
Jun 2005
Milwaukee, Wi
550
Greetings,
I'm looking for surface mount temperature transmitters. I have some pipes that I cannot insert a thermowell into. I know of the types that strap around the pipe, hose clamp style....They need to have 4-20mA out....Integral RTD to 4-20mA converter would be best because we don't have boxes in these remote locations. Just looking to see if there is something new that someone has used which I haven't seen....Thanks in advance.
Greg
We often strap RTDs to the outside of pipes in a 100 bar reactor. We specify the weld pad style probe but regular 1/4" works OK. If you can use some of the thermal cement used with trace heating cable. Our process is too hot to mount the transmitter in contact so we use a remote mount, any type will work.
Hello, I have been shopping around for a while, seems like alot of them will only inspect a small area. What I want to do is inspect a loading...
1,893
I'm curious if anyone has used a Surface Pro with Wonderware? I developed the application in 1920 x 1080 and that is the resolution for the main...
1,555
If you didn't see Microsoft's press event they released the Surface Pro 4 but also a full laptop dubbed the 'Surface Book'. Looks like it could be...
3,023
Has anyone tried using a MS Surface tablet with Windows 7/8 to run RSLogix 500 or 5k? Seems like a nice alternative for simple field...
3,869
This isn't a question but more of a Answer for many people who I know have been thinking about this. We have a Surface Pro that I have got running...
2,258
