Swapping a PF4/40 for PF525
TRW0930
Aug 2007
New Brunswick
Hi. I have been tasked to update a plc project for my work. Currently, the project is controllogix platform and controlling several drives. The main drive pf40, connected via 22-comm-e and then uses the DSI port to connect to two other drives pf4. What sre the steps to complete this project easily. How much programming will there be involved? I believe it may be easier to do the main drive (pf40) first then swap out the pf4 later. I am able to set the drive up parameters and IP address, just not sure about the programing to exchange the drives. Any help will be grateful. Thanks:site:
I have done this in older systems with no problems, Logix5000 v19, RSView 32 HMI. Just be sure to name the drives exactly the same, I usually copy the name from the program and paste to notepad to be sure. There were no programing issues I ran into.
Hey guys, the scenario is: I have already completed the drawing package for my system utilizing an A-B 440R-N23126 (Minotaur) safety relay. SoS...
154
I just finished a project that was using a CompactLogix(5069-L310ER2)and the project now requires a GuardLogix(5069-L310ERS2). I will be...
634
I had a processor go out on a PLC rack. I am trying to use a different processor because that is what the customer had available. Original was...
1,243
I need to swap out a compact logix 1769-OB16 does the firmware and the series have to match with the new one. Can I upgrade or downgrade the...
1,089
Hi, Looking at installing a L8x redundancy system and have perused the manual. Yep version 1 (beta..) on L8x, probably not the best idea, as well...
1,421
