Symbol Import
PLATIPUS
Guest
P
HI ! I JUST UPLOADED FROM A SLC5/04 A NEWER VERSION OF THE ORIGINAL PROGRAM.COMMENTS AND NAMES OF COURSE R MISSING. HOW DO I IMPORT THEM WITH RS500 ?
I had the same problem (if I'm reading your post correctly) and the fine people here answered the question. See my post, RSLogix 500 Documentation dated 8-1-02.
There are two ways that I use, (possibly more) depending on a lot of information that you have not provided.
If you have an offline file of the program with documentation:
Method #1
1. Delete all offline files associated with this particular processor that do not have documentation.
2. Attempt online again.
3. When you get to the go online pop-up screen, select "Upload, use file" (if a file is found)
Method #2
1. Open the documented offline file in RSLogix500.
2. Goto "Tools">"Database">"ASCII Export"
3. Save the files as RSLogix500 type in a folder you will be able to easily find later.
4. Close this file.
5. Open the saved file "A NEWER VERSION OF THE ORIGINAL PROGRAM" as you call it.
5. Goto "Tools">"Database">"ASCII Import"
6. Browse for the files saved in step 3 above.
7. When these files are found, Highlight and click ok Repeat this 3 or 4 times, until all of the ascii files have been imported.
8. Done
If you do not have a documented offline file, you will have to find one, or start typing :)
I have a S7 project originally written in German that I am trying to troubleshoot. Can the symbol table be exported into Excel then translated and...
3,931
As I am new to the S7-200 PLC and the Step 7-Micro/WIN programming software, is it possible to import/export the symbol table to an ascii text...
5,150
Dear all, is there any easier way of importing s5 assignment list to s7 symbol table? I have converted s5 program to s7, also converted the...
4,074
I have an existing PLC with code in it that was sent from the OEM, I have gone online and uploaded the code, but obviously I don't have the...
1,908
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
102
