Symbol MS3204 2D Barcode Scanner - Omron CP1H
donl517
Dec 2005
Michigan
127
Anyone worked with this combination before? I bought the cable for SSI communication and I guess should have gotten the trigger cable instead. Anybody used one of these with SSI successfully? I don't quite grasp the concept of SSI. I made a cable adapter suggested by tech support at Symbol but it isn't triggering the scanner. Anybody with a sample program, it would be greatly appreciated.
Thanks for any help,
Don
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
131
I was looking for this function, so that i doesn´t need to do it in the PLC. If there are an alarm in the alarm list, i want to flash the...
577
Hello, fairly new to plcs I’m tasked with installing a PE to a micrologix1200, in the attached picture I/14 is the PE I’m installing it’s going to...
1,006
Hello Thank you all for your support. I am actually experience same issues with TIA portal V17 update5 as well as V18. The problem is with the...
823
Hi all, I've inherited someone else's program and can't for the life of me figure out his use of the # symbol in one of his structured text...
1,937
