Sync GE 90-30 TOD clocks to SCADA server
DHoward
Jul 2012
South Carolina
25
I have a system of about 16 PLC's all 90-30. I have a GE Proficy iFIX SCADA system two redundant I/O servers, a Terminal server (about 8 thin clients), and a thick client, Is there a somewhat simple way to have the PLC's synchronize TOD clocks with one of the SCADA servers?
Maybe, but depends on which CPU models you have, some will sync with SNTP, others will not.
It may be better to writing a script in iFix and send the time to each PLC at regular intervals then use the Time Service Request (SVC_REQ 7) in each CPU to update the clock if needed else just reference the time from the iFix loaded registers.
Thanks - They are all CPU364's and I found an app note for SNTP, but the links that it contained did not work. Is there somewhere I can get more info on this?
According to this AppNote: http://support.ge-ip.com/support/re...staging/KB/8000/KB8571/en_US/1.0/app00004.pdf
The CPU364 does support SNTP, if the links in it don't work use an Internet search engine to locate an SNTP server. For best control and performance, I suggest that you purchase one to put on your server
Try the GEIP support web site: http://support.ge-ip.com/support/index?page=home&locale=en_US&view=AUTOMATION
Or contact your supplier: http://support.ge-ip.com/support/index?page=spage&id=ST6&locale=en-US&locale=en_US
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
54
I have to start out by saying I am not a PLC programmer and I have basic programming skills but mainly use software as a troubleshooting tool. I...
135
Hi currently my existing PLC using AB motor & driver to spin production, however customer want to another set, if this possible we use different...
230
Hello, I am trying to create an AOI that will retrive the clock datetime bits from a master plc through a generic message read instruction and...
501
I have a problem with time sync working in this topology. I have a plc with grandmaster clock controlling motion groups. I wanted to add kinetix...
1,057
