I need some help with converting SYSWIN program to CX-Programmer. The PLC I'm using is "CPM1A".
I can first do a download to the PLC with the old SYSWIN codes, and afterward do an upload from the PLC using CX-Programmer. Everything works fine except one instructions cannot be converted properly.
It is the "PULS(--)" set pulses instructions.
In the old SYSWIN codes, it uses
Port Specifier: 0
Control data: 4
Number of pulses: 0
And in the CX-Programmer, the Control data doesn't allow you to use 4 as its value as they only allow 0 or 1. (SYSWIN allows you to use 0 to 5)
I was trying to hunt down any old manuals that allow me to define that control data number for SYSWIN, however I was without success.
I tried both value 0 and 1 for control data but doesn't seem to work.
So my question here is does anyone here know how I can go about converting this change without errors and will still function the same as SYSWIN?
Many Thanks
Port Specifier: 0
Control data: 4
Number of pulses: 0
Many Thanks
