TCP IP communication in Vijeo Citect
HenryDan
Sep 2009
Toronto
Hi there,
I am a dummy user of Vijeo Citect. I am going to communicate with Allen Bradley PLC via TCP IP protocol from Vijeo Citect. My problem is that I can not configure the OPC(OFS) to connect Vijeo runtime to the plc and because of that problem when I double click of the "Express I/O Device Steup" in Citect Explorer nothing was happend. Please help me
Thanks,
Henry
I BELIEVE that Vijeo is basically the same as "normal" Citect.
If that is the case then you are talking about two different protocols, firstly you state "communicate with Allen Bradley PLC via TCP IP protocol" then later "I can not configure the OPC(OFS) to connect" you do not need to use OPC. You can set Citect up to communicate directly to Allen Bradley PLC's. What sort of PLC ? SLC500 , PLC5 or ControlLogix ? In "normal" Citect the I/O device setup is also available from the Tools menu available in the Citect Explorer.
They are basically the same, Vijeo Citect just has some extra features when used with Schneider products (linked database and some extra libraries)
Hi I'm using a Magelis HMIGTO6310 and want to communicate with an barcode scanner. The scanner I'm using is a Leuze and it supports Ethernet...
3,103
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
55
Hi, i cant establish communication between fatek plc with an energy meter, both capable for modbus tcp, i did with modscan but fatek plc does not...
161
can i send and recieve data using my yokogawa UT35A controller with my siemens s7 1200 plc using profinet communication without using gsd file
388
I am trying to establish communication between Siemens PLC 1500 and Matlab. I followed a tutorial on youtube at this link: But when I got to the...
357
