Temp address Siemens s7-300
Solm86
Mar 2017
Egypt
21
Dear experts,
I have a question about temp interface address,
If i have a temp "temp75.temp78", and i found that this address in DB7, and this temp address take "0.2", does it means that the long address is "DB7.DBX0.2"?
I attached 2 photos
Awaiting your reply
I noticed that i searched for this address long address but not found
I searched for the address "DBX0.2" as a Short address i found it in DB8 not DB7
Temp addresses are local to the code block (OB/FB/FC), and not stored in a DB anywhere.
I think it would be addressed as L0.2, if I recall.
The objective: Reach about 10’ horizontally into a 1300F furnace, and pick up a 140lb rectangular container, then pull the container back out of...
1,880
Hi Everyone, We have Silo System which has temperature sensor and these sensor data will be communicating through RTU unit to the Dedicated PC...
620
We have a small plastic parts oven (SP at 210F). It used to have an old bimetal temperature regulator. We are upgrading it using two temperature...
1,540
We have a vertical Axis which was overheating while not moving. After further investigation I found that when the axis moves upward to a...
1,216
Needing some help. I have a machine that was put in storage and has ended up in my lap. It had a 5/02 originally but the card was pulled and I...
1,421
