Temperature Monitoring
Jon R
Jan 2007
Tadley
206
I am looking at monitoring the temperature inside a PLC enclosure to feed back into an HMI, but I haven't used thermocouples/Pt100 before. Heater/fan switching is going to be done by normal thermostats.
I have looked at the price of both and Pt100 sensors are more expensive than than thermocouples. Is there a reason for this, and which one is the preferred solution?
I don't need any great accuracy just to provide a temperature that I can use as an alarm trigger in case of the fan/heater failing and the temp going out of the desired range.
Jon.
Hi Jon,
We've used these before - i think they were approx £30 ish...
We've sent them on the outside of our panels to several African locations to monitor the plant room they were installed in.
Hope this helps.
Rob
Thanks Rob, I'll have a look at that it certainly seems a neater solution than a bare probe.
Jon.
Jon
I uploaded a temperature sensor comparison table here
Hi all, & a happy New Year. it's been a long long time since on the site, & true to form I need your help once again. I have been tasked with...
2,780
Hello everyone! I have a task to measure the temperature outside and inside of a building, and compare them. I am working with the xcp pro, and...
2,159
I was wondering if anyone has ever had to setup a system to monitor temperature of the contents of a parked stationary railroad tank car. I can...
2,557
I set up a project so that it could be run in complete Manual control if needed, or so I thought. Eight monitored temperatures are displayed via...
5,014
Dear All, I'v 1 project which is monitoring 100 channels of thermocouple's temperature by PANASONIC PLC. Any suggestion for this project ? which...
2,939
