Terminal Block Numbering
Tim Ganz
Dec 2010
Dallas, Texas
691
I am laying out terminals for my control panel in AutoCAD. I will have a strip that will ahve nothing but Grounds. I have an existing strip labeled TB1. Should the strip with grounds be labeled TB2 or something like TBG for grounds?
How do you do it?
I will usually label a complete terminal strip like this: DCTS1 or ACTS1. I will normally put the grounds at the end of the strip. I will then label the wires DCTB1-1 OR DCTB1-GND.
I normally use the green and yellow terminal blocks and do not label it since it's self explanatory. Some others I have installed have a ground bar screwed to the backplate with just a ground symbol next to it
Yes I don't number or label the green blocks either. Just the standard ones. If I just a bunch of blocks together to make a Neutral or DC Ground bus I wont number those I just put a N or a - on the label.
I usually incorporate ground blocks into my other terminal strips but don't label them. Personally, if all there is on the strip are grounds it is functionally identical to a ground bar, which I don't label.
What about mixing AC and DC wiring on the same strip? I have TB1 can it contain ac and dc wiring or should I make a seperate strip TB2 for DC wiring?
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
121
Hello everyone, I'm trying to find a DIN mountable terminal block with an LED/indicator light that will light when the block has power. The...
1,378
Does anyone know if the front face of the terminal block can be removed for ease of connecting the wires? I'm referring to the screws circled in...
2,189
I'm having a hard time finding the manufacturer of the terminal blocks shown in the picture below. They're very similar to the AB 1492-CA...
1,608
Which Style to you expect to see on a drawing? Which style to you prefer? Keep in mind this being used on very large projects Style 1 Style 2
21
6,753
