BudW Member Join Date Sep 2005 Location Detroit, MI Posts 107 Feb 2, 2007 #1 Is there any NFPA 79 (2007) or NEC rules that state what side of a terminal strip that Internal or Field wiring must connect to when inside a enclosure? Bud
Jim Dungar Member J Join Date Apr 2002 Location WI Posts 1,152 Feb 2, 2007 #2 No. This is a design not a standards issue.
BudW Member OP Join Date Sep 2005 Location Detroit, MI Posts 107 Feb 2, 2007 #3 Thanks Jim. Had to argue with a customer to that fact and your answer helps re-enforce my opinion.
curlyandshemp Lifetime Supporting Member Join Date Jul 2005 Location Toronto Posts 1,903 Feb 2, 2007 #4 BudW said: Thanks Jim. Had to argue with a customer to that fact and your answer helps re-enforce my opinion. Click to expand... I assume a customer was complaining that the field I/O had to wired by a left-handed electrician?
BudW Member OP Join Date Sep 2005 Location Detroit, MI Posts 107 Feb 2, 2007 #5 curlyandshemp said: I assume a customer was complaining that the field I/O had to wired by a left-handed electrician? Click to expand... Yes, That was the argument, the left-handed electrician had to stand on his head in order to wire in the I/O. Up-side-down the other way around.
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Feb 2, 2007 #6 But the customer is ALWAYS right.
