test a current output 1762-OF4
One more note, your meter that didn't work probably has a blown fuse inside it from when the last guy left the leads and knob on mA and checked a 120vac source with it.
I am building a test rig which will have two 50HP dc motors connected together, which will me used to test the motors/drives under current...
3,366
Hi, I am using M221 reading from 3 different sensors (modbus rs485) sharing same bus (daisy chain). I am currently using READ_VAR (in total...
87
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
189
See code at the bottom. Hi all. For the story, this is my first complete project using a Rockwell PLC, I've been mostly working with Unity Pro...
795
My question is regarding the number of Test outputs vs the number of inputs in a module. In the case of a 1734-IB8S card, there are 4 test...
1,197
