Test code on real HW (S7-1513 or higher)
EStufC
May 2019
Kikuara
69
Hello,
does anyone have an opportunity to test a code (small FB, SCL) for me on real hardware?
Hardware: S7-1513 or higher.
I need just look at trace which would show how a certain code behaves while executing on HW I mentioned above.
here is a source file and its appearance in the project.
-please put it in, for example OB30 (create it) with cycling time 3ms.
-set 5ms for FB sole input.
-assign FB outputs as per picture attached
-create trace in accordance with outputs
-perform trace
-make trace export
-do upload here
if you have any questions - please ask.
  • Test_FB.zip
Have a look. It's the first time I've done a trace, so not sure if I got it right.
It's first time I did an import of trace. :)
I see no blanks and missing pulses. Did you follow timings (5ms) and 3ms for OB30 cycling time?
cardosocea,
do you remember which setting was when you performed that trace for me? OB1 or OB30?
Look at attachment please.
How can I test some PID code I have written for a SLC-500 in RSLogix500, without having an actual processor to test on. I have used Emulate500 to...
1,833
Hi guys, I am running some communication tests with an s7-1500 and I want to see what effect high cpu load / scan time has on my communication...
2,604
A bit off topic. I don't understand what these guys are doing, it just seemed interesting/bizarre and somewhat related to what goes on here...
1,740
Hello everybody, I'm new in PLC and I have a chance to hand on a PLC system; however, my Boss give me a Laptop with a folder of many PLC code and...
10,647
I have a panelview 1000 (2711-K10C8L1) that is giving an error 74 on boot. I just replaced the displays in it. I noticed the firmware was old so I...
4,851
