Tester
Caveman
May 2002
Cadiz, Kentucky
212
I'm currently building a Stat Cable Tester for molding, and was wandering if anyone else has done this.
It checks the ground wire.
It checks for pins shorted to ground
It checks for shorted to another pin
It checks for open
It checks for reversed
cables to check are:
6 Pin Mainfold
24 Pin Manifold Thermocouple
32 Pin Tip or Thermocouple
Micrologix 1200 L40-bxb, extra 16 input
and 16 Output.
Panelview 1000 C3
Thanks, Jeff K.
check the thermocouples for correct wire with a mV meter.
check the cables with low amps and high amps to be sure of good connection.
the sequence can be done with plc, however only if it are more as say 200, for less do it manual,
If in cabling business use a setup with relais so you can put anything on any wire and let the relais scan every wire apart.
Put a mV meter on the benchtop and press Go.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
145
Hello guys, I had a problem in a local network where I have a lot of devices to a Stratix 8000 administrable Switch and this one to a 1756-EN2TR...
489
Has anyone worked with a Cosmo Air Leak Tester(LS r-902) with Ethernet/Ip, to connect to A Compact Logix, I´m doing a proyect with this equipment...
2,061
Hi all, Hoping some of you have some recommendations for an all in 1 tester, the most well known brand here is megger so 1 by those would be great...
1,813
Good afternoon all, hope everyone is doing well. When using an insulation tester on a powercable and motor that's fully disconnected from a...
2,239
