Testing a AB L83E Program without controller
Jul 2007
Kiruna
600
I have a program I need to modify offline and test prior to commissioning.
Its developed in Logix V30. I have no L8x controllers available and the emulator is not an option when I attempt to change controller.
Is there anyway I can convert this to download to a L7x controller?
Unfortunately, Rockwell offers no path back to a differnet controller once converted to 5580 or 5380 controllers. If you were to create a blank project that is a L7x contoller and a blank project that is a L8x controller, you would find only a few differences between the L5K files. So similar to moving a project down in revision, you could edit the L5K to change it to a L7x controller. I have done this successfully with simple projects.
I don't know why they insist on this restriction. They are perfectly capapble of moving a project to the L8x platform, they have all of the information and expertise to move back, yet here we are.
Create a new project with the Emulate Controller.
Export your MainProgram from your existing project, and import it into your new Emulate project... but... you'll have to remove your I/O mapping routine because the real hardware won't exist.
Rockwell really sucks with emulation.
I had to create a new project. Paste all the UDTs, AOIs, tags, tasks in. Remove all IO references before I could download to an L7 or an emulator.
Going backwards is non trivial; the new generation of L80 controllers support features that the older L70's don't.
Nonsense, it would be trivial for them to do this. Just like it would be trivial for them to allow you to save as older revisions. The fact that you can start a project with the older architecture controller and just import everything from the newer architecture should tell you something. The software could and should do this.
I just took a functioning project with about 20 devices in the tree, edited about 6 lines in the L5K, plus 1 line per device in the tree (search/replace). I now have a project that was a L310ER, now is a L33ER.
Edit. I suppose you could have been using unsigned types that are only supported on the newer platform and run into trouble there, but they could certainly flag this and allow you to fix it. If you are intending ongoing back to an older platform, you intend not to use unsigned types.
Agreed. Simple yet effective revenue generation strategy.
I'm not that cynical, I think it's just being out of touch with users. I can understand how it happens in a huge organization.
I'm very new to this field, but I really think that these are conscious decisions.
I remember asking you for the RSLogix Upload/download tool a while ago. I conducted some successful testing to use it as an automated 'Build' tool with my git repo. When I wanted to standardize it across my company, I wanted to officially get the tool from Rockwell. My pathway was to initially contact the support line. They emailed me back saying "We like to ask our customers for more info when requesting this tool".
I emailed them our requirements, clearly stating that I already had AssetCentre, and wanted to have an independent pipeline for my git repository. They were really not satisfied with that one apparently, as the next thing I know, I got an email invitation from Rockwell for a meeting with 4 big-wigs from the AssetCentre development/Logix Designer development team.
I was like sure, let's see what awaits us here. It was an hour long meeting, and I was expecting some positive response from that, but it just turned out to be a lengthy advertisement for AssetCentre. Again, this was after I told them that we already have a multi-10s-of-thousands-of-$$$ license for AssetCentre.
I really believe that they want to control the narrative. It's a deviation they do not want, why? I don't know the goals apart from $. If it was possible, they'll give out APIs for "Component of logix designer" executables they use for uploading from the AssetCentre Disaster Recovery Agent. The user already bought Logix, they shouldn't wall the full usability, at least not for the pro edition.
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
104
Hi all, I have a AC current transducer that I want to bench test to ensure I am getting a 4-20mA output. I am using a AE001 unit. It is very...
119
Hi Guys, Can ControlLogix with Modsim32 for Modbus Server Testing? I have ControlLogix via Anybus Modbus TCP and I need to Test the...
325
Hello all, looking for ideas on getting some basic training done, I need to practice on maintenance timers and bypass switches (with a Factory...
1,320
I have a project in FTV ME (Studio v13) that I'm trying to apply security to a few buttons/setpoints. I have 4 users: Anonymous Logon, DEFAULT...
791
