dbh6
I don't know but i remember someone telling me that say for example you have a contactor or a relay generally if the coil is energized the corresponding contact will either close if they are NO or open if they are NC. Now in the instance where you energize the coil, you should have continuity between the NO contact terminals this is when their is no power flowing through the contacts. So say you do the same test but with either 24vdc or 120vac passing through the contacts and test for continuity will that cause any issues???? Generally when energized with power flowing through i test for voltage but want to know if the continuity test would be ok as well
