TesysT over ethernet
Steve_D
Jul 2002
Albury/Wodonga
92
Schnieder have bought out a all encompassing DOL motor starter/monitor...the TesysT range. I have a Premium PLC running unity and have set up an IO scanner in my ethernet card. My issue is I cant see how to adress the words in my TesysT unit, how many words in and out and what data is allocated to those words. If I knew what data was where I need just scan the IP adress and suck em out. I have the power suite software which lets me do everything but allocate the words. Can any one point me to some usefull doco or example projects?
Does anyone have experience using these things? Can't get it to work for the life of me. I've used the Schneider cable to set the IP and I can...
2,302
Hello all, This is my first time for using HMISCU, but I have some problems during programming. How can I transfer Embedded IO of HMISCU to...
974
156
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
89
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
273
