the right PLC
cryoman
Jun 2002
Pacific Nortwest
I have been looking for a PLC that will perform several basic operations listed below. There is no shortage of units that have a lot more digital outputs and inputs, on them then I really need.
Specs:
2 analog inputs 4-20ma
2 analog output 4-20ma
8 digital inputs (120 vac)
8 digital outputs (120 vac)
Explanation:
I have a cryogenic processor that takes metal down to -300 F at about 1 degree every 2 minutes and back up to +300 at the same rate. Right now I am using a Watlow controller (installed at the factory) and it has very limited controls. The unit over ramps and short cycles between heat and cold which waste Liquid Nitrogen and is very costly.
I do have access to a Modicon compact 984 but the cards are very expensive and the software program is expensive.
dave
Easy!.... Stop over at Automation Direct and check out the new DL06 PLC. If you could get by with only 6 AC outputs, the DL05 (8in/6out) would be a lot less expensive, but the DL06 is still pretty cheap... And the DL06 is much more expandable than the DL05 anyway
DO-06AA 20in/16out - $259.00
F04AD2DA-1 4in/2out Analog 4-20ma module - $185.00
PC-PGM-BRICK Programming Software - $149.00
D2-DSCBL Programming Cable - $29.00
Just over $600.00 for EVERYTHING! It would be under $500 if you could use the DL05
Hmmm... Can you tell I'm a big fan of A-D stuff?? Sorry, but I just got the new catalog and haven't finished drooling over it yet... :D
-Eric
diego escobar, The same info that Eric listed way back when we all were younger still holds true, plus they have lots of neat new goodies, too.
You really dug up an oldie but to-the-point goodie!!!
David
Hi All, I have a programming background but have never used a PLC. I have what I think is a simple automation project however Im not sure of the...
19
1,871
Good Day everyone, i am currently wiring up a panel and i am not sure if a L36ERMS compact guardlogix controller is just used for safety or you...
573
Good day all. I work for a small company that would like to start automating the production of our goods. I have been tasked with doing some...
49
13,620
Could someone point me to a DB9F right angle cable that would allow me to close the door on a L61 PLC? Certainly one exists but all I can locate...
1,793
With Windows 7 End of Extended Support being just under 3 years away (Jan 2020), is the time right for someone like Inductive...
45
13,301
