Thermistor configuration in TM221 PLC
riz123
Mar 2018
dubai
I have TM221CE40R controller along with TM3TI8 temperature module.
Temperature sensor we are using is Thermistor with below part no.
AXIO Annicom : AX-TE-IT 10K3A1
Honeywell : PF20-65-2M NTC 20K
But I am not able to understand what setting I need to do in channel configuration to get proper values.
I tried different combinations in Minimum and Maximum values but its not getting resolved.
Kindly assist me to configure this thermistor in PLC.
1. active or passive?
The Axio spec sheet says that 'active' has a transmitter that converts the raw sensor signal to 4-20mA (current); passive is the raws sensor signal (resistance). Your file name says 'active', but your part number for the Axio is for a passive thermistor.
Are you sure your sensor assembly is really a passive resistance and not an active 4-20mA signal from a transmitter?
2. pg 100 pdf, https://download.schneider-electric...=EIO0000003131.01.pdf&p_Doc_Ref=EIO0000003131
I do not know what Schneider's configuration method is, but it appears that you configure either NTC or PTC,
and one of the thermistor parameters (configuration per channel):
R: 0...65535 (1 Ω /LSB)
T: 1...1000 (1 °C/LSB)
B: 1...32767 (1 K/LSB)
3. What is not obvious is how the input knows whether it is a 10k or 20k or whatever, nor how one reconciles a 2400 part resolution over a specific -90 to 150°C span.
Hi Danw, Thanks for your reply. I am trying to configure my sensor as NTC. But I tried with PTC also. But my measure issue is how to scale it. Means what parameters I need to put for channel configuration to get proper temperature value...
I have a motor with 2 thermistors. One pair reads 1.0 ohm and the other 247 ohms Does this indicate one of them is bad? Which one? Also these...
1,727
Can someone explain how a Powerflex 525 drive interprets the PTC Thermistor signal from a motor winding? How does one know what the levels are or...
4,073
Thermistors........Can someone explain how they work and how to control the speed of a vfd with them? I am not familiar with thermistors, but a...
31
6,023
Hi All, I am trying to interface the PTC thermistor output from the Allen Bradley motor to temperature controller-CN245 from Omega. The relay...
1,421
Dear all, I am driving 11kW induction motor from Schneider Altivar ATV28 VFD. My 11 kW motor is equipped with thermistor but i am unable to...
3,415
