TI 510 Drum Sequencer
tmyersdv
Jun 2007
Ohio
I have an old TI 510-1101 processor system and I am in need of some help with a Drum instruction? I have been searching for a programming manual for the 510, but have been unable to locate one.
Does anyone have access to the page / pages which show the Drum instruction?
Thank you,
Todd
Thank you,
Todd
This is from the 5X5 series, hopefully it will enlighten some things
That is helpful, however it has created a couple of more questions. I found a setup sheet for the drum and it has an entry for "scans/count" = 1
I assume that the time for each step is counts entered in each step * scan time.
Does anyone know the typical scan time for this 510 unit?
Also, in certain steps the count/steps = 0, I would assume this step would only be on for 1 scan?
Thanks for the help so far.
Todd
I'm trying to set up communications between a OI.MBTCP I/O server (for our historian) and a COMX510 that is on the same network , the COMX is also...
660
Hello, I am dealing with a AB PanelView 5510 device which needs to be accessible via VNC (local only, NO internet access!). To enable the VNC...
2,054
Hey guys, Currently struggling with a fault I get on a Lenze i510. Fault - F7180... This happens when a piece of debris gets wedged in our track...
1,821
Hi! I am using an M200 PLC connected by Modbus TCP/IP with a Com'X 510 energy server. I need to read the data corresponding to the voltage of a...
1,044
Does anyone have a TI510 PLC programming manual?
1,142
