TIA portal missing CPU in HW catalog
lenka
Feb 2016
Opatov
Hello All
I have a smoll problem with TIA portal:confused:
I'm using TIA portal V13 SP1 Update7
I have a problem with hardware configuration. I dont have in hardware catalog CPU 416-2xk01-0ab0 and also I missing ET 200 153-1aa030-0xb0. I tried to instol GSD file for ET 200. instalation was successful and I restarted hole PC but I still dont see it. I tried uploade HW confic from PLC but I get message "The hardware configuration was created and downloaded with an incompatible version of STEP7. Could not upload hardware configuration"
My suppoort packages is up to date and also all software has updated.
Any idea how I can get the CPU and ET to my hw catalog?
Lenka
I only use the 1200 so this may not apply for you. After I start the software one of the options is 'Installed Software', then to 'Detailed Information about installed software', then to 'Installation of support packages' and 'Download from the Internet'. Only problem is that the file that lists what each support package is supposed to support, doesn't exist if you click on it. So you would have to download all packages to see if your CPUs are supported. You did say that your support packages are up to date, but I didn't know if you knew about the option to download new ones.
Hello Siemens experts. I am trying to register a GSDML file for an Endress & Hauser's Profinet IO over APL (Profile 4.0) compliant device. TIA...
214
I've got an issue opening a project in TIA Portal v16. When the file is opening, I get the message that says "Optional products used in the...
734
Hi, I have an XB208 which has V4.3 firmware on the device. I only have V3.0 showing up on my TIA portal (V15). Can anyone share how I get the...
1,308
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
101
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
89
