TIA portal v13/14 question
one2go
May 2016
Cakovec
51
Hello,
I'm testing some stuff and I'd like to know if there is possible way to change TIME(via HMI) when interrupt will occour in OB10 (time of day).
Thanks forward.
Cheers!
Check out SET_TINT or SET_TINTL under Extended Instructions -> Interrupts _> Time-Of-Day Interrupts.
You would need to enter the time on the HMI and convert it to the data type that the instruction needs, but there are time conversion instructions in Extended Instructions -> Date and time-of-day that should make that not too difficult.
I am working on a program that was developed in 2015 for an S7-300 safety PLC. The new copy of this machine uses an S7-1500 safety plc. We were...
1,902
Hi Guys, Please, I'm in need of TIA Portal v13 SP1 The V13 I saw can't open a Comfort panel HMI file. Can any one help? It will be much...
5,420
TIA Portal V13 with 1515 Processor. TIA Portal being run on VM. For many weeks, was able to go online and monitor blocks while troubleshooting...
3,998
We had hard drive failure and lost our most recent backup of one of our TIA Portal V13 projects. I uploaded the current program from the PLC...
4,224
Hi, I try almost everything but not solve the problem. As attached is the screenshot of the error from Tia Portal, There seem problem with the...
4,107
