TIA Portal V13 Cyclic interrupt
Manglemender
Jul 2007
Lancashire
1,295
Hello all,
I've decided to have a play with TIA Portal V13.
In Step7 you can evaluate the value of the temp variable #OB35_Exec_Freq to determine the setting of the cyclic interrupt. Can anyone tell me how to determine the execution frequency of a cyclic interrupt programaticaly in TIA Portal ?
Nick
Type of CPU?
On a S7-1500 you add the cyclic interrupt block, and then configure the interval in the dialog in µs. You can change the interval later using the block properties dialog. The OB number doesn't say anything about the interval as it was on the S7-300/400.
You can use the instructions SET_CINT and QRY_CINT to either change or read the the interval and other cyclic OB parameters. The instructions can be found under Extended instructions -> Interrupts, and are valid for either the 1200 or 1500.
I am working on a program that was developed in 2015 for an S7-300 safety PLC. The new copy of this machine uses an S7-1500 safety plc. We were...
1,902
Hi Guys, Please, I'm in need of TIA Portal v13 SP1 The V13 I saw can't open a Comfort panel HMI file. Can any one help? It will be much...
5,424
TIA Portal V13 with 1515 Processor. TIA Portal being run on VM. For many weeks, was able to go online and monitor blocks while troubleshooting...
3,998
We had hard drive failure and lost our most recent backup of one of our TIA Portal V13 projects. I uploaded the current program from the PLC...
4,227
Hi, I try almost everything but not solve the problem. As attached is the screenshot of the error from Tia Portal, There seem problem with the...
4,107
