Time Of Day problem from WinCC Flex to SQL
userxyz
May 2002
any
2,768
I have a problem with the Time Of Day datatype.
On the HMI I have this:
The Date is shown in the format type date.
The Time is shown in the format type time.
The Tags Date are datatype Date.
The Tags Time are datatype Time_Of_Day.
Okay, with this script I write to an SQL database:
This is the result in the SQL Database table:
The Date is okay.
But the time is not okay. Even when I use varchar datatype as you can see. I've tried to use time, but that's not the solution because I then get a long decimal number...
It's a bit confusing that in DB's the Time datatype needs to be Time_Of_Day and on the HMI the format type needs to be time (else the date is vieuwed also. But for the SQL database I cannot find a solution to eliminate the date in the time column.
Anyone knows what to do ?
Thanks in advance,
Regards,
Gerry
I'm trying to migrate a ProTool program to WinCC Flexible 2008 Advanced and when I open WinCC and say open a ProTool project, I get 2 errors. The...
9,118
Dim i, a(10) For i = 0 To 9 Step 1 a(i) = SmartTags("visuf")(i) Next For i = 10 To 2 Step -1 a(i)= a(i-1) a(0)= SmartTags("valuetag")...
5,488
Hello everyone, Info: I am using WinCC Flexible Runtime to log data to a SQL server. It is set up to log production values every minute from...
20
11,354
Hi all, I have winncc flex 2008 project that I am working on. I have a MP377 panel connected via ethernet to a S7-300 which is working fine. I...
9,380
Hi All, I am new here and from Down Under. My problem: I have WinCC flex 2008 SP1 HF1. After compiling I have the next error message: Internal...
3,965
