wincc flex and pc runtime problem
mrt19
Mar 2009
Virginia
42
Hi all,
I have winncc flex 2008 project that I am working on. I have a MP377 panel connected via ethernet to a S7-300 which is working fine. I am trying to connect pc with runtime to the same plc. The problem is I cannot get runtime to run on the pc. I can transfer the project okay but in runtime the pc will not communicate with the plc. I have tried 3 different pc all with the same result. However, I have a laptop that connects and works, but the pc's will not. Some errors I get on the pc are:
140004 - Incorrect access point
140001 - Connection disconnected
170003 - error code 0x80000104
Any ideas on what is going on here. It is strange that the same project will work on my laptop but will not work on a pc. Any help or suggections are greatly appricitated.
Thanks,
mrt19
On the target PC, go to the Windows Control Panel, and start the Set PG/PC Interface applet.
Here, set the acces point S7ONLINE to TCP/IP.
Also, the IP and Subnet of the PC must match the IP and Subnet of the PLC.
awesome
Awesome, this site is great and has never let me down. I have been working on this problem for days and you solve it just a few minutes. I should have posted question days ago.
Thanks JesperMP!
MRT19
Three years later and JesperMP's answer solved my problem after searching Siemens websites for an hour.
Thanks!
Hello! Another weird request from the swede with customers that doesn´t like to pay for quality in first place... Is there any way to have a...
2,682
Hi! Writing this in a hurry. Today we made a break at a factory and I should download new s7-1200 program and a new WinCC Flex 2008 RT program...
2,244
Hello Experts, I have a problem in WinCC Flex 2008 Sp3, when I start runtime system , after 2 to 5 sec when it started to communicate with the...
1,710
I have a Siemens project with 2 HMI screens, one is a KTP600 Basic and the other is a MP 277 10inch touch. When I fire up the runtime from within...
4,455
Hello everyone, Info: I am using WinCC Flexible Runtime to log data to a SQL server. It is set up to log production values every minute from...
20
11,351
