time travel
ganutenator
May 2002
kansas
1,440
ok, not exactly.
want to program an event in a plc (m340) to start some light display during a particular time.
the delio, is that depending on what they put in for the start time and stop time, it could intend to work at night (outside the range) or during the day (inside the range).
I originally had it programmed as:
start when time equals set point
stop when time equals set point
problem w/ that, is it confused the customer if they changed the range and it didn't come on or turn off.
rough draft
Code:
(*Idle Bay Light Show*)
(*No cars entering, washing, or drying runs light show.
If they did get a wash w/ dryers, then end of drying
If they didn't get dryers then end of wash + 15 seconds
(*reasons to inhibit the light show
entering
wiu
dryer_sign_start
LightShowEOWTof (IN := WashInUse, PT:= t#15s);
If entering or WashInUse or dryer_sign_start or LightShowEOWTof.q Then
	LightShowInhibit:= true;
else
	LightShowInhibit:= false;
end_if;
(*turns the start and stop times into minutes to determine if the start time is less than the stop time.
start time less than stop time = time active during day
stop time less than stop time = time active during night*)
LightShowStartTotalMin:= LightShowStartHr * 60 +  LightShowStartMin;
LightShowStopTotalMin:= LightShowStopHr * 60 + LightShowStopMin;
CurrentTotalMin:= CurrentHourInt * 60 + CurrentMinInt;
If LightShowStartTotalMin < LightShowStopTotalMin Then
	LightShowOnAm:= true;
	LightShowOnPm:= false;
elsif LightShowStartTotalMin > LightShowStopTotalMin Then
	LightShowOnAm:= false;
	LightShowOnPm:= true;
else
end_if;
If LightShowOnAm & (CurrentTotalMin >= LightShowStartTotalMin) & (CurrentTotalMin < LightShowStopTotalMin) Then
	LightShowTimeActive:= true;
elsif LightShowOnPm & not((CurrentTotalMin >= LightShowStopTotalMin) & (CurrentTotalMin < LightShowStartTotalMin)) Then
elsif (LightShowStartTotalMin = LightShowStopTotalMin) Then
else
	LightShowTimeActive:= false;
end_if;
(*Time Control For Idle Bay Light Show*)
If ((LightShowTimeActive & LightShowTimeEn) or LightShowAlwaysEn) & not LightShowInhibit Then
	LightShowActive:= true;
else
	LightShowActive:= false;
End_if;
So you have three times
Ts Te Tn, for start end now
You have 6 possible combinations
Ts <Te<Tn OFF
Ts <Tn<Te ON
Te <Ts<Tn ON
Te <Tn<Ts OFF
Tn <Te<Ts ON
Tn <Ts<Te OFF
So do something like
Code:
If Ts <Tn and Tn<Te
  ON
Elsif Te <Ts and Ts<Tn
  ON
Elsif Tn <Te and Te<Ts
  ON
Else
  OFF
Endif
Sort the syntax out yourself
Ts <Te<Tn OFF
Ts <Tn<Te ON
Te <Ts<Tn ON
Te <Tn<Ts OFF
Tn <Te<Ts ON
Tn <Ts<Te OFF
Code:
If Ts <Tn and Tn<Te
  ON
  ON
  ON
Else
  OFF
Endif
dang. going to have to look at this in the am. but if your code legit, i'm going to feel like a moron for over writing.
Hi all, This is my 2nd post and I just want to say thanks for your feedback! I appreciate every single one of your responses! I have been...
17
1,784
A customer of mine has a problem. His AB PLC5 1785-L40E is faulted, and the plant is at standstill. He cannot get online to diagnose the fault...
19
3,526
This has been a very touchy subject at my workplace for awhile, so I'm curious what your companies do for pay hourly guys? Travel to customer? Do...
20
8,073
Can anyone explain the different Rockwell servo travel modes to me? I see three options under the setup: unlimited, limited, and cyclic. I...
1,874
Hello All. We had an incident yesterday where the hard overtravel limit switch was stuck, which we didn't find out until some wasted time...
1,499
