timer
balouji
Feb 2011
tehran
hi guys
how are you?
I set the input of timer in simatic manager to MW0
but when the amount of MW0 became more than 1000ms it cause SF in my CPU314
what should I do please guide me
thanks before
dear LD
you know I want to insert for exampel 2h20min to timer not directly, by MW0 or other ...
how can I do that?
thanks for your reply
dear LD
how can I do that?
S5T#2h20m =
2#0011_1000_0100_0000
S5T#1h35m10s =
2#0011_0101_0111_0001
please compare the above with the image L D[AR2,P#0.0] posted.
2h20m = 140m = 8400s therefore 10s time base required (3) and timer value = 840 in bcd, thus value in MW0= 3840 Hex
Dear L D[AR2,P#0.0],
This's my 1st post on this forum.
Thanks for the reply as it helped me as well(alongwith the originator of this thread) to get the "insight" of the S5TIME format ...... actually into binary bits !!
Siemens says , the maximum time this syntax can hold is 2H_46MIN_30SEC.
Is this beacause the max BCD digits run upto 999 and considering the maximum time base of 10s(bits 12 and 13 = 1 and 1), it will come to 9990 sec which is eventually 2h_46min_30sec?
OR Am I going wrong?
Regards
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
102
Hi all, I have a simple question that I have overcomplicated and gotten stuck on. I have a variable, we can call it "light" that I need to stay...
342
Question to anyone with ideas about my thoughts on upgrading a very vintage timer, which is being used to switch between 2 5hp domestic water...
451
why my timer only executes once here? After first time i use it, ET stays at 0ms all the time. It is in FB
322
Good morning guys, I'm searching for a Timer relay which accomplishes the "flasher" condition in the photo attached, however, I need the ability...
560
