How about the old emergency thermocouple weld trick?
1. Pour some mercury into a small clear glass jar, so that you have approximately a 1/2" deep pool of mercury.
2. Pour about 2" of oil (mineral is preferred, vegetable will work) on top of the mercury to act as an arc suppressor.
3. Connect the neutral (white) wire from a 120 volt AC power cord to a heavy washer or other weight to hold the wire in the bottom of the jar, so that it is immersed in the mercury.
4. Connect the hot 120 volt AC wire to one end of your thermocouple extension wire, twisting both TC wires together and splicing to the power cord with a wire nut.
5. Twist the other ends of the TC cable together
6. Plug the cord into a 15 amp 120 volt receptacle.
7. Lower the twisted TC wire ends into the mercury.
When it touches, there will be a small arc, the TC wires will weld together in a small neat bead, the mercury will be blown away from the wire, and the oil will suppress the arc. Now you may safely remove it from the jar. An instant thermocouple weld was made. It is fast, easy, and I have never had an accident, tripped a breaker, or had any problems in making hundreds of thermocouples over the years.
The problem nowdays is finding some mercury. We used to play with it, but now it is considered to be an enviromental hazzard. If you do find some (old thermometers), save it for future use!
