TON .DN bit confusion
ssas
Sep 2018
Pakistan
Hello Members,
I am new learner of PLC and I am experimenting with Rockwell Automation Softwares.
I have attached my logic file, it is basic traffic signal program. According to my understanding, initially when the program start to run, Yellow_Timer.DN bit is 0 and hence XIO contact is high, which is causing Red_Timer to enable and it starts timing, meanwhile Red_Light OTE is high for 30 sec. After 30 sec, Red_Timer.DN bit will be high enabling Green_Timer, turning OFF Red_Light and turning on Green_Light for 25 sec. After 25 sec, Green_Timer.DN will be high to enable Yellow_timer, turning Off Green_Light and turning On Yellow Light for 5 sec. As soon as, 5 secs complete Yellow_Timer.DN bit will be high, causing Yellow Light to turn off, according to my understanding this bit should remain high and Red_Timer should not be enabled again. But in actually it goes back to 0 and Red_Timer get enabled again, what is causing this bit Yellow_Timer.DN to set to 0 after 5 secs. Please explain.Thank you
The yellow_timer.dn is XIC which will reset the red timer and that in turn will reset green timer which will reset the yellow timer and that will return the yellow-timer.dn to it's normal state of closed and starts the red timer.
Also, look at the timer.TT bit. It could simplify your light output rungs.
I'm using one TON (called SystemTimer) throughout a program that I change the .PRE given different conditions. I'm porting an IDEC ladder over to...
318
Hi, I'm just looking for a simple way to make a button in excel (via VBA I presume) to toggle a bit in RSLogix 5000. I just got FactoyTalkLinx...
548
Hi, I am using the DN bit to stop the timer. However the DN bit doesnt change state. Please see the attached image. Any help is appreciated.
2,826
Hey Guys, I have a normally closed contact in a PLC I'm needing to create a button in Wonderware to toggle this bit on & off I have a button...
6,900
Can any one point me to the complete bit assignments of the timers? TIA LW
1,686
