EX10*MPI21 Programming Questions
Greetings... here are two text boxes pasted in from the attached PDF I uploaded which contains the Ladder Logic from the program on the machine I am working on which is the Toshiba EX-100, namely- EX10-MPU11A CPU; the usual inputs and outputs and this mystery module which is a PULSE INPUT module fed by a Red Lion Encoder- Model: ZNH1200H
When the HOA is in AUTO, the rotary knife is adjusted to cut the pad on the mark by two photo eyes which input a digital signal when the mark is sensed by the first sensor and then the second sensor. They are about 12" apart on the feed line. In addition there is an encoder signal input to a Toshiba MPI21 (Module-Pulse-Input-21). The data below: " [IN [2 ] XW02 ] - [ XW03 W - >W D0000] " and elsewhere in the ladder is related to this. It is taking the PE-1 and PE-2 digital signals and looking at the data from the encoder at a certain moment to determine when to move the knife pilot motor which speeds up or slows down the gear box for the rotary knife
SEE PAGE 7 FOR MORE EXPLANATION AND SPECIFIC QUESTIONS...
Here is where the rotary knife is made to speed up or slow down in order to stay within the two black marks on the paper. The rotary knife is driven by a large motor - gear - box unit, and there is a very small pilot motor which moves the gears for faster or slower speed. Output Y010 and Y011 below in Network 7, rungs 01 through 06 are the relay outputs which control a Minarik D.C. Drive Card via control terminals for Forward and Reverse.
The problem: in Auto, the knife cuts are drifting and not staying on the mark, so they have to put the system in "HAND" and use the pushbuttons for "+KNIFE" and "-KNIFE" shown on rungs 3 and 6 below. Prior to being called in on this, the encoder was replaced by someone else. I am going to look at the connections and the possibility of "homing", as well as look at the signals going to the MPI21 with a Fluke ScopeMeter.
I am asking for any other ideas and advice.... and I am endeavouring to understand the EXPDD software symbols for the MPI21, for example- what exactly does this mean in plain English: "[IN [2 ] XW02 ] - [ XW03 W - >W D0000]" and similar terms in regard to reading and manipulating the numbers coming in from the encoder ?
