TOSHIBA MDR40S ouTPUT
jimmyz
Apr 2005
Hi all
I was recently asked to program a Toshiba Plc - MDR40S, i have gotten to the point of verifying the input (24vdc), the led lights up to show, i can redirect for the output which works as well, the led corresponds, but when i test for output voltage there is any.
I am in desperate in need of help
At a guess; YOU have to supply the voltage.
There is none present but you will see several COMMON terminals. This is where you supply the output voltage. (relay outputs)
hi all I am new to the PLC enviroment i was given a toshiba plc mdr40s and told to make it work. Can someone assist me or point me in the...
2,765
Hi, I have two Toshiba G3 Tosvert-130, one of them I can see monitoring mode, I can control with the LCD display, recently I changed the presets...
347
I inherited a system with the Micrologix 1500 talking to 8 VFDs using Modbus RTU protocol. One of the VFDs was replaced with a Toshiba VF AS1...
1,207
Another software thread! We have a Toshiba EX100 that's just been working away quietly in a panel for 20 years, never causing a problem to...
1,205
Hi, Any body had success to change parameters in between a Toshiba Inverter VF-S11 using a Red Lion any series (mine is K304), and MODBUS RTU...
1,158
