Kind of !
I went through the same phase that everyone goes through - random key strokes and mouse clicks , with tongue hanging out of the mouth , a bit of dribbling .
But after a while it becomes easier (or more familiar) , and I actually enjoy messing with it now . I have a 315 with ethernet card hidden in a cupboard , wireless networked , and a 314 , also with ethernet card , so I can fairly much simulate anything I want , including ethernet/profibus comms , without having to see the PLC , just by stiing at my desk - how is that for sad ?
I'm working on an iMAP job now - Siemens , totally integrated automation - sounds good doesn't it ?!? and I must confess that while the software is complete , the comms are reall getting on my wick - I have an MP370 , but there is also control via WinCC , and also inter PLC commands and responses .
As a for instance , I have a big DB that controls all my motor starts and stops , if a bit is set on the hmi , it is reset by the control block , however with this job , I have to copy from a profinet DB to the command DB , but only when a command is received , after the control block resets the command bit , then the entire DB has to be copied back to the profinet DB to reset the command from SCADA -
Only reason I am telling you this is because no one else will listen to my ramblings .
