TP170B SIEMENS Update OS
Rastaban
Oct 2018
Europe
Dear Friends,
i have a problem with a Siemens TP170B.
I can't transfer my project by MPI of my PC.
Error Message in attach.
I can't resolve the situation. I try the bootstraping by serial but not resolve.
Can someone help me?
Kind Regards
Rastaban
In order to perform an OS update, you have to load an image file.
You will probably find it in
C:\Program Files (x86)\Siemens\SIMATIC WinCC flexible\WinCC flexible Images\Mobile_OP_TP170B
I have had success with this by a serial connection, with a null-modem cable.
You have to connect the cable, select the "reset to factory settings" in the OS update dialog, start the OS update with the proper image, and then cycle power to the panel. Then hopefully the OS update goes through succesfully.
Greetings i need to do programming / configuration for a new Siemens TP170B what connection cable do i need ? if it is attached to Siemens...
2,419
Hi Im using Compact Logix L32E PLC and Siemens TP170B HMI using Win cc flexible.How to communicate between this two? There is no Ethernet port...
3,380
Hello, I have a service engineer on site, and he is struggling with a touch panel. The touch pointer is way off where he is pressing the touch...
4,518
Hi, we are using Siemens S700 PLCs with add-on modules and use the TP170B screen (and the replacement TP177B). A service engineer with thick...
5,385
How do i setup the tp170b on profibus to the plc without useing protool?
3,349
