tp177b font problem
seee
Dec 2010
singapor
112
hello dear all.
As a project the customer ask me to translate all texts to
persian but the panel TP177B COLOR PN/DP shows squares instead of the right font.
before transfering project to the panel i tested the project with simulation
and all fonts are correct in both languages(english and persian)
but the problem(squares instead of persian fonts) occures when i transfer the project to the panel.
For your information i use wincc flexible 2008 sp3.
best regards.
According to Siemens tech support entry 26187049:
"Panels with Windows CE or Linux as the operating system do not support fonts written from right to left. This is only possible with WinCC flexible PC Runtime. "
So you might be out of luck.
We have done a couple of right-to-left language projects with WinCC Flexible.
As Mike says, it must be a PC RT. You can use a regular PC and an relatively inexpensive 128 tags license (if the project is not so big), or a full Siemens Panel PC with runtime license.
Hi everyone I'm having trouble transfering a projec from my PC(wincc Flex 2008 sp2 Win7) to an HMI simatic panel(tp177b pn/dp 6"cstn). I 've...
3,566
Hello, as you might know, the TP177B is no longer in production. However, we do have a lot of them in our machines, so some spares would come in...
19
5,002
Dear all, We have two machines and we have the same sytem running on the both, and TP177B 6" color HMI is installed on both, one of them got some...
2,534
hello i have system with cpu315f DP and HMI TP177B DP 6 inch it`s first time to make configuration for hmi with s7300 so i have some questions...
1,511
Hi, I'm trying to log process data with a TP177B :bawling: I know it doesn't support Tag Logs, or seemingly anything else that's useful :P...
1,316
