Transfer project from PC to HMI(tp177b pn/dp 6"cstn)
raguilas
Dec 2015
Sinaloa
48
Hi everyone I'm having trouble transfering a projec from my PC(wincc Flex 2008 sp2 Win7) to an HMI simatic panel(tp177b pn/dp 6"cstn).
I 've tried with serial, usb-usb and ethernet(crossover) cables with no success, all I get is a message error when I click on overwrite on existing file :cry:
Error message says: "The DLL tr_ce_HmiEs.dll was not found"
"The transfer DLL was not found"
panel configuration:
http://s20.postimg.org/45t3dh47x/transfer_settings.jpg
before trying to dowload the project I activate the transfer mode:
http://s20.postimg.org/us5k2g8f1/transfer.jpg
video where shows what I get on screen:
https://youtu.be/Yl5m3ilVUsg
I was thinking about using an SD card instead though I don't know if those are compatible with this HMI, I suppose if I use one it should be formatted before saving the CSV files and save them on the SDcard adapter(microSD) directly on the root.
I hope you could help me with some of your knowledge.
Thanks in advanced, best regards.
You don't even get to the part where it actually starts to download - so it's a wincc/your computer kind of problem.
There are some bugs in wincc with download on 64 bit machines (and perhaps others too).
I suggest you update your wincc to SP3 and the latest updates.
Then when wincc is working and you are going to download, the system will want you to update the OS as well in the HMI. Just so you know.
You don't even get to the part where it starts to download.
Then wincc is working and you are going to download, the system will want you to update the OS as well in the HMI. Just so you know.
OK thank you very much pal, I'm gonna upload to sp3, best regards :D
Hi I tried to upload the SP3 but got an error message when installing the first or second component from SP3 update 1, installation cancelled itself.
after that I tried to dowload my project and the WINCC asked me to confirm the panel OS update(I didn't get this before), until then the panel let me do the transfer, it was great an such a relief thanks.
I checked if my wincc got updated to sp3, certainly it wasn't cause installation was cancelled almost since the beginning.
so transfer was a success even though SP3 installation wasn't.
for any one interested in the settings that worked for me, you can check out the following pictures.
"wincc config"
http://s20.postimg.org/iho4m9qcd/CONF_WINCC.png
"transfer settings"
"set on transfer mode"
"used PPI cable with this speed 9.6k"
http://s20.postimg.org/l5dkwmjdp/20160421_172608_HDR.jpg
"after downloading I plugged what seems to be a standard serial cable from
the panel serial port to S7200 port 1"
http://s20.postimg.org/5mg4zib31/20160421_172458_HDR.jpg
http://s20.postimg.org/yq4cvqz6l/20160421_172504_HDR.jpg
with this standard serial cable and connected like mentioned before is the way I got communication between panel and the PLC and activate/cancelled/visualize the PLC bits.
I could notice when transfering the project that if by any reason I made a something differently I couldn't dowload the project and even if changed the
settings correctly, because the wincc platform got stuck and had to close and reopen the project then I could download with no problems.
Have everyone a great weekend, thanks for your help Pete S. best regards.
I followed the Noobs guide , but i got stuck at this point http://imageshack.us/f/69/flexible.jpg/ i loaded the Step 7 program then i opened...
7,967
hi, I've tried to download project from laptop to HMI, but impossible. HMI and laptop can ping together .But when i pressed transfer, it announced...
3,316
We converted the WinCC project. But it was difficult. A lot of scripts were running in the background. The only problem at the moment is...
556
Hey guys, our s7-300 broke down yesterday and i wanted to take the same project from it and transfer it to another s7-300. But i do not know how...
4,681
1,357
