tp270 10" communication problem
jugenzhu1963
Jun 2006
toronto
72
Hi everybody
When i try to upload project from siemens tp270, i got this message "could not find the pdz file" and the process is aborted. The tp 270 is connected to the profibus on which there are one 313c-2dp cpu and one et200s remote i/o. The nod address of tp270 is 1. i set up the upload setting to "mpi/profibus". i use 5512 card on my laptop with windows xp. i can communicate with plc. somebody knows the means of "pdz file" and how i sould do.
thanks lots
I think you can only upload from a TP270 if the option "enable upload" was enabled when the project was downloaded, at least for ProTool (I'm not sure about wincc flex).
In TP270 with WinCC flexible - exactly the same way.
To be able to uplad project later, before download, you have to enable option "Enable back transfer".
Eventually you can make backup useing ProSave.
Hi Myself Nijas, I am facing a problem that I have to programme one new HMI TP270 (Siemens)(no programme exists in TP). For that serial...
1,581
Hello everyone, I'm trying to communicate a TP270 panel (Siemens) with a S5 135U CPU928B PLC. The conection I've is like this: PLC ->...
1,633
I have a TP270, I have the profibus cable connected between the HMI and PLC, I have the PLC profibus address set as 2, on the HMI under the...
2,205
Hi there. I’m new in communication between HMI Siemens and PLC Simatic S7-200. I need to communicate a CPU 226XM with a HMI TP270 and I don’t...
4,059
Hi guys, I have a trainer with a Siemens S7-315 Processor and a TP270 HMI, using an MPI adapter to connect. I have gone over every setting I can...
1,757
