TP270 communication with S5
juanmdx
May 2007
SLP
281
Hello everyone,
I'm trying to communicate a TP270 panel (Siemens) with a S5 135U CPU928B PLC.
The conection I've is like this:
PLC -> Siemens converter TTY/RS232 -> Adapter D25 to D9 -> RS232 cable (also from Siemens) -> Panel
The RS232 cable is plugged to the IF 1A port of the panel (the one with RS232 communication).
But there is no commuication, I can't read or write anything to the panel.
Anyone knows what might be happening?
Juan
Hi
This problem is familiar ... First get the pin lay-out of your cable and match it to the PLC.Is that converter a cable or a black box with external power.The first panel we installed ( OP270) we could not get comms with a converter cable .we then bought a PSM-ME-RS232/TTY converter from Phoenix .This box is active and supplies the voltage( for the milli-amp loop) to the PLC.
The connection on the OP or TP is AS511 on IF1 A .
On the OP/TP you also have to change some settings in control panel
Under transfer check the serial port on channel 1 ( but not the remote)
Hope it helps and don't except a fast screen update .The best we could get is about 3 seconds to update about 20 tags on the screen .If possible group all your tags into one block of 128byte or less.
Eric
Hi Myself Nijas, I am facing a problem that I have to programme one new HMI TP270 (Siemens)(no programme exists in TP). For that serial...
1,581
I have a TP270, I have the profibus cable connected between the HMI and PLC, I have the PLC profibus address set as 2, on the HMI under the...
2,203
Hi everybody When i try to upload project from siemens tp270, i got this message "could not find the pdz file" and the process is aborted. The...
4,257
Hi there. I’m new in communication between HMI Siemens and PLC Simatic S7-200. I need to communicate a CPU 226XM with a HMI TP270 and I don’t...
4,058
Hi guys, I have a trainer with a Siemens S7-315 Processor and a TP270 HMI, using an MPI adapter to connect. I have gone over every setting I can...
1,756
