Werner
Hi there!
I have a motor with encoder. With this encoder I can calculate which angle the motor is making. I want to show the actual angle of this motor on a Siemens TP 270 10". I was thinking about a circle represanting the shaft. On this circle a want an indicator (line) showing the actual angel of the shaft. Anybody any idea's? The line object is difficult because 0 degree is horizontal which would result in line thicknes 0. Minimum line height = 1. With this height half of the line is not vissible!
