TP270 Sinus circle
Werner
Apr 2005
IJsselstein
336
Hi there!
I have a motor with encoder. With this encoder I can calculate which angle the motor is making. I want to show the actual angle of this motor on a Siemens TP 270 10". I was thinking about a circle represanting the shaft. On this circle a want an indicator (line) showing the actual angel of the shaft. Anybody any idea's? The line object is difficult because 0 degree is horizontal which would result in line thicknes 0. Minimum line height = 1. With this height half of the line is not vissible!
Maybe the clock object is possible? This is what I'm looking for. But unfortunately the time properties of the clock object are not changeable.
Try the XGauge Control. Set the Min. Value to 0 and the Max. Value to 359.99. In the Display area, set Minimum Angle to -90 and Maximum Angle to 270. You should get a circular gauge that has 0 degrees at the top and a needle that appears to move in a circle. Adjust the other settings to get it to look just right.
Hi guys, I have a trainer with a Siemens S7-315 Processor and a TP270 HMI, using an MPI adapter to connect. I have gone over every setting I can...
1,762
Dear all, We are using a TP270 6" in our machine we dont have the original back up of the touch panel having two problems. 1) m trying to upload...
1,822
Hello everybody! I have a question about PLC CTI 2500 model C200. We have device with this controler but it hasn't a operating panel. I want...
1,855
Hello, I am using step7 v5.5 and wincc flex 2008. I have created my PLC program have it working, but I am having trouble with my...
16
10,114
Hello to all and thanks for your interesting website I was trying to get data from Siemens TP270 panel using WinCC flexible2008 When Downloading...
3,329
