Millwright
I have a system that has 2 chains with 3 lugs on each chain on a common shaft. The lugs have to be within 1mm of each other as they push a panel through a saw or the panels are crooked. Currently we have to measure everything manually on each set of lugs to ensure it is square.
I want to track the offset of the 2 lugs opposite each other at a set location. Contrologix 1756-L71 processor, Powerflex 700 VFD on the chains, photoeye can be whatever is required. If the offset is more than 1mm I would like to alarm it on the HMI. Chain speed is 250 ft/min.
I am told by my programmers that the scan time is too long to be able to do this with even with the fastest P/E and PLC Card available from AB. My questions are:
1. Is it possible with AB equipment?
2. If not should I try Beckhoff because they have faster scan times?
Any assistance appreciated.
