Transfer OPC Tags from WinCC to S7-315 PLC
henno2000
Jan 2007
UK
72
We have some OPC variables that are transferred into WinCC through the RS232 port via National Instruments Lookout OPC Server/Variable Engine.
What I am wanting to do, is transport these variables into a PLC.
What is the best, most efficient way of doing this?
Regards,
henno2000
I've same problem, have you found the solution? I really apreciate if you tell me the solution :)
Regards
Hello Everyone, I am using a raC_Opr_NetModbusTCPClient AOI module, as below,. So, I need some assistance to restrict in reducing the poling...
152
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
89
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
106
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
138
Hi all, Im having trouble transferring a program from one panelview 550 to an new one. I can insert a flash card into the old panelview and upload...
20
401
