Transformer and solenoide brake
jblkiller
Nov 2010
Quebec
I have a solenoide brake for motor. I would like to know which capacity industrial control transformer (VA) should I use because on the nameplate on the solenoide brake the are 2 capacitys. The AMPS INRUSH: 4.3Ampere and the AMPS HLDG: 0.3Ampere.
Primary voltage: 208V, Secondary voltage: 120V
The inrush is a killer, and that load puts you right above 500va, but I would not try to go any lower than what is required at inrush. Are there other loads?
Size for inrush, plus some overhead. I'd add 25% at least; who knows when someone will take a look at that transformer and say, "Oooh, I'll just get 120v from here!"
-rpoet
Folks, I am designing a control system for an industrial machine. Machine is 480VAC / 3PH powered. And I have a 480 / 120V transformer for control...
1,413
Hi all, I know this sounds like a dumb question, but.....I'm thinking out loud...and maybe I shouldn't do that.... Upcoming project involves...
4,165
Ignore - I asked this question already and found my answer.
1,032
Hi all Where can i find this transformer ? Pri 480 v 3x 0.12 A Sec 400 v 3x 0.12 A 3 phase Type DTS 80 50/60 Hz
3,583
Greetings experts, Can current transformers be used on the incoming mains (480, 3P) of a machine that has regenerative VFD's? Current...
3,240
