Translate German to English, comment of DB
Alpha
May 2003
35
Hello! This is our data block for PID controller. I can not read the comment written in German.Could someone help me translate these comments to English? Thanks.
__________________________________________________
Tension controller
6: KY = 005,000; AUSGABEFORMAT DER EINZELNEN WERT
13: KF = +00000; "YIO"WERT I-ANTEIL BEI 39.1 HI
14: KF = -00004; "Y"STELLGROESSE IN % x 10
17: KF = -01000; "YU"STELLGROESSE UNTERGREN.%x10
18: KF = +01000; "YO"STELLGROESSE OBERGREN. %x10
21: KF = -00021; "XWU"REGELABWEICHUNG Lower Limit
22: KF = +00021; "XWO"REGELABWEICHUNG Upper Limit
23: KM = 01110000 00000011; Control + Registration Byte
28: KF = +00001; "TA" Secs x 10 (SAMPLE TIME)
30: KF = +00000; "HY" Hysteresis x 10
31: KF = +00020; "TS" STELLGLIEDLAUFZEIT
34: KF = +00016; Control O/P normalised 0->10000
35: KF = -00044; STELLGROESSE NORM.AUF 1000
37: KF = +08193; DL=Unused DR=ABBILD VON TA
39: KF = +00001; Control Bits [STEU]
40: KG = -4363158+02; "Y" STELLGROESSE
42: KG = -1535132+02; "XW(-1)"VERGANGENHEITSWERT XW
44: KG = +0000000+00; "YD" DIFFERENZIALANTEIL STELLGRO
46: KG = +0000000+00; "YD(-1)"VERGANGENHEITSWERRT YD
48: KG = -2028065+03; "YI" INTEGRALANTEIL
Translation
If you would tell what do you command with this program i could be more accurate in my translation
6: KY = 005,000; OUTPUT FORMAT OF THE INDIVIDUAL VALUE
13: KF = +00000; "YIO" VALUE I-PART AT 39.1 HI
14: KF = -00004; "Y"POSITIONING VALUE IN % x 10
17: KF = -01000; "YU"POSITIONING VALUE ?UNTERGREN?.%x10
18: KF = +01000; "YO"POSITIONING VALUE ?OBERGREN?. %x10
21: KF = -00021; "XWU"OFFSET Lower Limit
22: KF = +00021; "XWO"OFFSET Upper Limit
31: KF = +00020; "TS" TIME OF THE EXECUTION PART
35: KF = -00044; OFFSET NORM.ON 1000
Thank you.
This data block is a data area for tension controller(PID regulator) in a Department Drive System, but not a positioning system.
GETrans V1.6 could not translate the automatic technology words.
42: KG = -1535132+02; "XW(-1)"VALUES IN THE PAST XW
44: KG = +0000000+00; "YD" DIFFERENTIAL PART OFFSET
46: KG = +0000000+00; "YD(-1)"VALUES IN THE PAST YD
48: KG = -2028065+03; "YI" INTEGRAL PART
Just curious what is the quickest and cleanest way to translate all of a s7 project from German into English? I assume that I would export all the...
3,040
I need to Translate a Siemens S7 project into Delta PLC. I am responsible for Electrical so I will not care about software. Delta does have PLCs...
1,197
Can some one transfer this to ladder logic please L #InR T #PuntoX L #Punto2 L #Punto1 -R T...
1,990
Helo guys, New to siemens and STL . Can some one translate this ladder logic. In simatic manager when I change language it doesnt work. A...
2,288
Hi folks, I'm working on a glass jar packing machine and trying to figure out how this STL code works. Most of the code is in ladder or FBD. But...
25
9,275
